'09 QX56 thermostat replacement
jadedguy1990
Joined
Mar 6, 2025
Messages
2
Planning to replace my 2009 qx56's thermostat but when i look online they usually only offer the traditional flat style gasket and im pretty unsure where it fits. i'm a bit confused as i think the rubber seal around the thermostats edges seals the housing cover when and only when its installed correctly. can anyone confirm this please? also, my mind is blowing regarding the torque specifications for the 3 bolts thats supposed to secure the thermostat housing and thinking if the orientation of the bleed valve matters during the process of installation.
hi there! i looked this up and found that throttle body bolts is 74 in-lbs. intake bolts is 73 in. i will be using those settings. hope this helps .
Latest posts
Back
Top
